- Jul 18, 2011
- Guelph, Ontario, Canada
What the elfing Santa Clause does my GPU/CPU have business idling around in the 40-45 degree CELSIUS range on a 35 degree day...? Since this afternoon, my chipset/GPU/CPU temperatures in my system (featuring Swiftech's Apogee XT CPU block for my i7; alongside MCR320-XP and MCR220-XP radiators + gear I have in this beast) have stayed at a steady 40 degrees. This does not concern me. However, since it is now 2am, and has been 25 degrees outside for roughly 4-5 hours, is it still natural for my GPU/CPU temps to be idling in the 40-45 degree Celsius range? Now it's starting to concern me. How long does it take for the liquid inside the loop to cool back down after a whole day's worth of heating up to nearly 40 degrees?
The temperatures seem a little high, especially under load (Just Cause 2, Crysis 2 for examples) as this is quite literally 20 degrees above ambient room temperature. Under load the CPU can reach an impressive 55-59 degrees.........%$&# !!!!! I'm just so lost! Do I need new thermal paste?
SPECS
Corsair Obsidian Series 800D featuring:
i7 975 Extreme Bloomfield STOCK SPEEDS
12GB Corsair XMS3 1333
Rampage III Extreme
HD 5970 2GB STOCK SPEEDS
Swiftech Loop w/ MCP355
120mm RADS/ dual
120mm RADS/ triple
7 fans total with 6 out of 7 functional at the moment
some hard-drives and bla bla bla bla
Thanks for any information you may have!
SPECS
Rampage III Extreme
120mm RADS/ dual
120mm RADS/ triple
