I'm having 2 problem with this mobo. In administrative event viewer I get these 2 errors. Asus p8z77-v pro
Event id 13<---I get this every 1 or 2 days
: The embedded controller (EC) did not respond within the specified timeout period. This may indicate that there is an error in the EC hardware or firmware or that the BIOS is accessing the EC incorrectly. You should check with your computer manufacturer for an upgraded BIOS. In some situations, this error may cause the computer to function incorrectly.
Event id 137---->I get this every time I put the PC to sleep
The system firmware has changed the processor's memory type range registers (MTRRs) across a sleep state transition (S4). This can result in reduced resume performance.
If you don't see these errors could you tell me:
1. What BIOS version you're using?
2. What is the EC and ME version in the BIOS? You can see it in the time & date settings.
3. Are you using secure boot?
4. What chipset driver are you using?
I have posted this issue in other forums. I only got responds from 2 p8z77v users. I need a respond from a p8z77v-pro users.
http://rog.asus.com/forum/showthread.php?31990-P8Z77-V-...
