- Feb 5, 2001
- Calgary, Alberta, CanaDuh
90% water, 10% vodka. Works pretty decently for me
Diggrr said:As far as I know, the blue stuff is ~30% alcohol, distilled water, and some mild detergents & color in small ammounts.
Bugsmasher said:89.9% Distilled Water
10% Prestone Low-Tox Propylene Glycol Anti-Freeze
2 teaspons Iodine (anti-growth)
Small sidebar for the guys not using distilled or even more purified water. Even drinking water generally has minerals etc in it that will eventually cause buildup in a system. Go with distilled. Its cheap, easy to get, and will save you having your cooling slowly taper due to buildup in your HC and other places.
***EDIT***
NovaShine- I vaguely remember reading that standard food dye is actually fairly corrosive. Ya might do some checking around on it just in case.
azianese said:I use 5% zerex and 95% distilled with some orange dye.
If I don't have any aluminum in my system can I get away with just using distilled water? The zerex pretty much overtakes the dye and the color barely shows up and I think it clouds the tubing. After hearing that zerex doesn't even reduce temps either I am guessing that you really only need it if you have aluminum in your system unless it kills algae too.
NovaShine said:so what should i use to kill all the crap in my tubes?
Bad ConNecTioN said:Some use a couple teaspoons of Iodine, or use a little alchohol. Some also use anti-fungal tablets from pet stores that disolve.
Hell, Koolance uses the anti-fungal agent found in women's yeast infection cremes.
Some say its not really needed when using Zerex, Redline, or an anti-freeze.
