- Mar 16, 2012
I have two computers that both run Windows 7 Home Premium (64bit); one is a desktop, named UBERDESKTOP, and the other is a laptop, aptly named UBERLAPTOP.
The laptop was bought new with Windows 7 already installed (from Walmart), but it didn't come with a recovery disk, only a recovery partition. I recently had to recover it due to Windows errors, so it's still a fresh machine with only Windows Updates and other pertinent applications (Java, flash, etc.) I've already removed the bloatware.
Both computers connect to the internet and are in the same workgroup (WORKGROUP.) When I set up the homegroup, the desktop flawlessly connects to the laptop. I am able to view the shared libraries/folders and all is well. However, the laptop cannot connect to the desktop. It shows that a connection exists, but when I attempt to open a library or folder in the homegroup, nothing happens. (The homegroup troubleshooter is worthless and has not helped, I've tried.)
I've also disabled streaming within the homegroup, as I've read that it has been known to cause problems.
Homegroup settings:
Network Discovery: ON
File and Print sharing: ON
Sharing so anyone w/network access can read/write: ON
File sharing connections: 128 bit
Password protected sharing: off
Allow Windows to manage homegroup connections
Incidentally, both computers have the same username and password.
So I decided to try to share folders. Again, I can connect with the desktop, but not with the laptop. When I attempt to connect with the desktop, I get a prompt for a password, enter it (my username and password), and I get immediate access. However, my laptop gives the error: "Logon failure; unknown username or bad password."
Here's the kicker - it will work in two scenarios. It will work when the laptop is in safe mode and it will work once the laptop first boots into Windows, so I'm led to believe it's either a driver or a piece of software that's inhibiting it.
Things I've tried:
Updating the NIC driver on the laptop
Changing domains
Using different usernames and passwords
Using no passwords
Laptop Safe mode (this works)
Not using wireless
Enabling file sharing for 40 or 56 bit encryption
Turning off media streaming
Deleting and re-creating the homegroup
Added DWORD value called LmCompatibilityLevel to HKLM|System|CurrentControlSet|Control|Lsa (value 2), per a post found in these forums
Could there be something else I'm missing? Oh - and I've owned this laptop for over 2 years and I've always had an issue with the homegroup, but never with shared folders.
I should add that there's no access to the group policy with Windows 7 Home, so the DWORD value is supposed to rectify that.
I'm sure there's a million more things I can type here, but this is getting a little long winded.
Homegroup settings:
Things I've tried:
Changing domains
Using no passwords
Not using wireless
