- Jul 20, 2004
all kinds of problems.
yesterday, i blew out my hard disk. total catastrophic failure. i fubarred XP, then actually got a SMART status of BAD, did the windows repair, which got me back to a totally fubarred desktop, tried to restore from backup which COMPLETELY WIPED MY C:/, which, remember was failed/failing hardware anyway...
i still thankfully have the entire backup, so im not loosing any sleep over it
BUUUT-
i dont have an XP disk (i used the standalone repair tool)
now, i can buy another XP disk ( yes, this will be my 4th or 5th one) because all my others were lost/stolen/scratched - which would mean a sum total of a 4 digit figure spent on XP over the years. thats right, it would then total over $1000 spent on windows XP. and buy a new harddisk.
1. lest say i do that, should i go SATA?
i can go open source, ive allready got a slick linux install, but of course, it wont do wireless. it just will not support it.
2. i can buy another modem, because my winmodem is not supported either, and do dialup OR
3. go ahead and run all sorts of CAT6 all over the place, and do a fully wired network and toss the really old wireless stuff, but still have the option of installing XP again as time funding allows down the road.
4. cough up the cash for XP, a harddisk, and a newer flavor of wireless networking...
5. some combination of the above?
considering the current climate of hardware and software, and a bit of future proofing, what is my best option in terms of where the money goes?
what will most likely satisfy my needs now and in the future?
sorry for the long post, im just a bit dizzy about what to do.
BUUUT-
