- Jun 20, 2001
- Vancouver, WA
Heya guys
I've been very lightly messing with Linux for a while (first installed Mandrake 9.1 about three years ago), but haven't really had any reason or excuse to dive much deeper than the bi-monthly screwing around in Cygwin.
That is, until my laptop started flaking out on me. Windows was being a bit of a pain, not correctly initializing my wifi card among other things, so I figured I'd reinstall and dual-boot linux on the thing. To make a long story short though, GPartd pwn3d my NTFS partition and I couldn't get my Windows restore stuff to work (I did manage to recover all the data prior to pwn4g3 though, so no real loss ).
Saturday morning I fire up the Gentoo Live CD and begin installing. After much ado about sound refusing to work (I couldn't determine if ALSA was compiled in genkernel or not, and recompiling the kernel was a total failure ), I threw up my arms and decided to take the Live CD's advice and follow the book.
~18 hours of compile time later ("emerge gnome" FTW! ) and I've got a Linux box with a GUI. w00t! Now off to bother all the good folks who reside in Alt OS about a few of my questions....
I apologize in advance if some of this stuff has been covered in countless threads, but true to n00b form, I haven't managed (or bothered in some cases) to find anything that answers my questions.
1) Sound. Whilst waiting for Gnome to finish emerging , I played around with getting sound to work. When compiling the kernel by the book I added in ALSA support and attempted to play some stuff. I emerged mp3blaster (a console MP3 player) and managed to start blasting some Pokemon music (I kid you not. The first song that played was the Season 5 Japanese Intro ) with almost no trouble (amazing considering all the difficulties I've had with ALSA in the past!).
After Gentoo finished though, I rebooted just to make sure everything was fine and dandy and after wresling with X got XMMS open and tried playing some tunes again. Nada. I dropped back to mp3blaster without success as well. Mixer levels are good, and channels are unmuted, so I'm at a loss as to what could have changed over the course of a single reboot!
2) Video. Again whittling away the hours Gnome was taking, I ended up emerging an application (fbi) which would utilize the framebuffer to display images. Framebuffer support was included with the kernel, so I knew it would work, and it did. w00tness. When I quit the app and returned to the console though, the right half-ish of my screen went wonky. Pixel rows (again, only on the right half or so) were wiggling horizontally, leading to an effect similar to when you've got the refresh rate turned up too high. I tried screwing around with the framebuffer config file to no effect, and eventually gave up when Gnome finished.
Rebooted and the problem was gone (phew!). I then struggled with X and my touchpad a bit (uber props to the Gentoo Wiki BTW!) and finally got Gnome to display in all its glory. I failed at getting XMMS to work (see above), so dropped to the console and the problem was back! It appears that it shows up whenever something uses the framebuffer (well, besides the console and ncurses interfaces), and since I don't know of any reset command, only a reboot (or switching back to X) fixes it I don't know if the problem shows up in the Live CD (I'm gonna check this though), but any ideas?
3) /dev/ZOMG! There are tons of devices in /dev. I mean, TONS. Even ones I'm 99.9% sure don't actually exist (for example, the 8th hard drive "hdh" ) I doubt they're hurting anything (other than my brain when I ls the directory), but is is possible to prune the list down to what I've actually got?
4) Packages. I looked through the --help of emerge, but couldn't find any way to list all the packages currently installed on my system. I don't really need to know this, but it'd be handy if possible...
Thanks in advance guys -- Hopefully I'll be seeing more of you in the future!
JigPu
JigPu
