- Mar 15, 2005
- Chicago, IL
Well, about a week ago someone gave me a dell Inspiron 600m. Since then Ive tried everything to over clock it. If anyone has any ideas please message me. Its a 2 ghz Dothan on an 855 PM chipset in other words no pinmod. Probably no pinmod even if i had a 915 chipset without some insane voltmod. I have been unable to find the PLL on it through trial and error so I decided to take it apart. Well when i took the processor cooler off there was next to nothing as far as thermal paste. So not thinking about it when i put it back together I naturaly put thermal paste back on it. Started it up said to myself hey I wonder if that changed the temps any. No, i don't have an idle temp for it, I work my computers they all crunch seti unless Im benchmarking.
But Its load temp went down from 78 (this is at the low end, if you were blocking the air vent with anything you'd see over 80 easily)
It didn't go down a little, it went down to 53 C. 25 cents worth of thermal paste lowered the temperature of my processor 25 C. Dell you cheap ********. I'd have to say im quite impressed with the pentium M. I'd like to get some more of these and start crutching away. They're low power, this one is only slightly slower then one processor in my opteron 185. AND IT RUNS COOLER, well now. BTW. no i didn't clean aything out of the heatsink or fan grill or anything, when i got it i blew air back through it to flush the crap out because i thought it was hot.
Anyway, the most important thing to take away from this is. If you want a computer BUILD IT YOURSELF. Cause when you do it you know your not going to cut corners and when your done you'll know how far you can push your system. Actually intel does, and I'm sure that processor would be long dead before 103 C. Keep in mind, you hard boil eggs at 100C!!!!!
I'm unsure what the actual thermal limits of this processor are but dell has the shutdown temp preset in the bios at 103C and i'd feel a whole lot better about cranking this one up to 2.5 or 2.6 ghz now. Just need to find a way.
