- May 4, 2009
can anyone tell me what i need to do to overclock my pc , im new to this i would like to get upto about the 3ghz
here is my pc spec thanks all for any help
daz
SiSoftware Sandra
System
Manufacturer : System manufacturer
Model : P5KC
Family : To Be Filled By O.E.M.
Version : System Version
Serial Number : System Serial Number
SKU Number : To Be Filled By O.E.M.
System Chassis
Manufacturer : Chassis Manufacture
Type : Desktop
Can be locked : No
Version : Chassis Version
Power Cord(s) : 1
Serial Number : Chassis Serial Number
Asset Tag : Asset-1234567890
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : ASUSTeK Computer INC.
Multi-Processor (MP) Support : 1 Processor(s)
MPS Version : 1.40
Model : P5KC
Type : Mainboard
Version : Rev 1.xx
Serial Number : MS6C79B30403699
Asset Tag : To Be Filled By O.E.M.
Location in Chassis : To Be Filled By O.E.M.
System BIOS : 64-0701-000001-00101111-070307-Bearlake
System Mainboard Properties
Removable : No
Replaceable : Yes
Hot Swap : No
On-board Devices
Onboard Ethernet : Ethernet Adapter (Enabled)
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 2GB
BANK0 - DIMM0 : Manufacturer0 PartNum0 SerNum0 AssetTagNum0 DIMM Synchronous DDR-SDRAM 1GB/64 @ 667Mt/s
BANK1 - DIMM1 : Manufacturer1 PartNum1 SerNum1 AssetTagNum1 DIMM Synchronous DDR-SDRAM 1GB/64 @ 667Mt/s
BANK2 - DIMM2 : Manufacturer2 PartNum2 SerNum2 AssetTagNum2 DIMM Synchronous DDR-SDRAM 2GB/64 @ 667Mt/s
BANK3 - DIMM3 : Manufacturer3 PartNum3 SerNum3 AssetTagNum3 DIMM Synchronous DDR-SDRAM 2GB/64 @ 667Mt/s
Chipset 1
Model : ASUSTeK Computer Inc (Bearlake) Processor to I/O Controller
Revision : A3
Bus : Intel AGTL+
Front Side Bus Speed : 4x 267MHz (1068MHz data rate)
Maximum FSB Speed : 4x 400MHz (1600MHz data rate)
Width : 64-bit
I/O Queue Depth : 12 request(s)
Maximum Bus Bandwidth : 8544MB/s (estimated)
Chipset 1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
Number of Ports : 4
In/Out Width : 4-bit / 4-bit
Multiplier : 3/1x
Speed : 1x 100MHz (100MHz data rate)
Logical/Chipset 1 Memory Banks
Bank 0 : 11GB DDR2-SDRAM 6.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR2
Bank 4 : 512MB DDR2-SDRAM 6.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR2
Supported Memory Types : DDR2-SDRAM
Maximum Memory Speed : 2x 800MHz (1600MHz data rate)
Multiplier : 0/1284x
Width : 64-bit
Memory Controller in Processor : No
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module 1
Model : OCZ2P800R21G
Type : 1GB DIMM DDR2-SDRAM
Technology : 16x(64Mx8)
Speed : PC2-6400U DDR2-400
Standard Timings : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Version : 1.2
Date of Manufacture : Wednesday, November 14, 2159
Memory DC Line : 1.8V
Set Timing @ 400MHz : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Set Timing @ 333MHz : 4.0-4-4-12 (tCL-tRCD-tRP-tRAS)
Set Timing @ 267MHz : 3.0-3-3-10 (tCL-tRCD-tRP-tRAS)
Memory Module 2
Version : 1.2
Memory Module 3
Model : OCZ2N800SR2G
Extended Information : mVN
Type : 2GB DIMM DDR2-SDRAM
Technology : 16x(128Mx8)
Standard Timings : 5.0-6-6-18 (tCL-tRCD-tRP-tRAS)
Version : 1.0
Date of Manufacture : Saturday, December 25, 1999
Set Timing @ 400MHz : 5.0-6-6-18 (tCL-tRCD-tRP-tRAS)
Set Timing @ 333MHz : 4.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Enhanced Performance Profiles : Yes
Profile @ 400MHz: Optimal : 5-4-4-15 (tCL-tRCD-tRP-tRAS) CR2 5.2V
Memory Module 4
Version : 1.0
Environment Monitor 1
Model : Winbond W83627DHG-A ISA
Version : 12.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 34.0°C / 93.2°F
CPU Temperature : 69.5°C / 157.1°F td
Auxiliary Temperature : 119.5°C / 247.1°F
Cooling Device(s)
Auto Fan Speed Control : Yes
CPU Fan : 2377rpm
System Fan3 : 12385rpm
Voltage Sensor(s)
CPU DC Line : 1.17V
Aux DC Line : 3.25V
+3.3V DC Line : 3.25V
+5V DC Line : 4.28V
+12V DC Line : 11.16V
Standby DC Line : 3.25V
Battery DC Line : 0.52V
PCI Bus(es) on Hub 1
Version : 2.30
Number of Bridges : 5
PCI Bus 0 : PCI (1/1x PCIClk)
PCI Bus 1 : PCIe (3/1x PCIClk)
PCI Bus 2 : PCIe (3/1x PCIClk)
PCI Bus 3 : PCIe (3/1x PCIClk)
PCI Bus 4 : PCIe (3/1x PCIClk)
PCI Bus 5 : PCI (1/1x PCIClk)
Number of PCIe Lanes : 22
LPC Hub Controller 1
Model : ASUSTeK Computer Inc (ICH9) LPC Interface Controller
Revision : A3
ACPI Power Management Enabled : Yes
Advanced TCO Mode Support : Yes
Advanced TCO Mode Enabled : No
High Precision Timer Enabled : Yes
Number of Precision Timers : 4
System Timer : 14MHz
Delayed Transaction Enabled : Yes
LPC Hub Controller 2
Model : ASUSTeK Computer Inc (ICH9) SMBus Controller
Revision : A3
Sound Adapter 1
Model : Creative Labs Sound Blaster X-Fi
Revision : A1
Type : AC '97
USB Controller 1
Model : ASUSTeK Computer Inc (ICH9) USB Universal Host Controller
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Model : ASUSTeK Computer Inc (ICH9) USB2 Enhanced Host Controller
Revision : A3
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 6
Companion Controllers : 3
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
USB Controller 5
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 6
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 7
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 8
Revision : A3
Version : 2.00
Interface : EHCI
Channels : 6
FireWire/1394 Controller 1
Model : ASUSTeK Computer Inc VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
Revision : M1
Version : 1.10
Interface : OHCI
Enhanced Support : No
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : Intel 801xx/63xx SMBus
Version : 0.02
Specification : 2.00
Advanced TCO Mode Enabled : Yes
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
PCIEX16_1 (1h) : PCIe 32-bit +3.3V Shared PME Half-Length Available (Intel Corporation (Bearlake) PCI Express Root Port)
PCI_1 (1h) : PCI 32-bit +3.3V Shared PME Half-Length Available (Intel Corporation (Bearlake) PCI Express Root Port)
PCI_2 (2h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCI_3 (3h) : PCI 32-bit +3.3V Shared PME Half-Length Used
PCIEX1_1 (3h) : PCI-X 32-bit +3.3V Shared PME Half-Length Used (Nvidia Corp ??? (0402))
PCIEX16_2 (4h) : PCIe 32-bit +3.3V Shared PME Half-Length Available
Port Connector(s)
PS/2 Keyboard - PS/2 Keyboard : Keyboard / PS/2
USB1_2 - USB1_2 : USB / USB
USB3_4 - USB3_4 : USB / USB
GbE LAN - GbE LAN : Network / RJ-45
AUDIO - AUDIO : Audio
COM 1 - COM 1 : Serial Port 16550A / DB-9 pin male
Audio Line Out1 - Audio Line Out1 : Audio / Mini-jack
Audio Line Out2 - Audio Line Out2 : Audio / Mini-jack
Audio Line Out3 - Audio Line Out3 : Audio / Mini-jack
Audio Line Out4 - Audio Line Out4 : Audio / Mini-jack
Audio Line Out5 - Audio Line Out5 : Audio / Mini-jack
Audio Line Out6 - Audio Line Out6 : Audio / Mini-jack
SPDIF_OUT - SPDIF_OUT : Audio / CD-ROM Sound Input
IE1394_1 - FireWire 1 : FireWire/1394
IE1394_2 - FireWire 2 : FireWire/1394
SATA1 : SATA
SATA2 : SATA
SATA3 : SATA
SATA4 : SATA
F_ESATA : SATA
SATA_E2 : SATA
PRI_IDE : SATA
USB5_6 : USB / USB
USB7_8 : USB / USB
USB9_10 : USB / USB
USB11_12 : USB / USB
FLOPPY : Floppy Disk
CD : Audio / CD-ROM Sound Input
AAFP : Audio / Mini-jack
FP_AUDIO : Audio / CD-ROM Sound Input
CPU_FAN : None
PWR_FAN : None
CHA_FAN1 : None
CHA_FAN2 : None
daz
SiSoftware Sandra
System
Model : P5KC
System Chassis
Type : Desktop
Can be locked : No
Power Cord(s) : 1
Power State : Safe
Mainboard
MPS Version : 1.40
Model : P5KC
Type : Mainboard
Version : Rev 1.xx
Removable : No
Replaceable : Yes
Hot Swap : No
On-board Devices
Chipset 1
Revision : A3
Bus : Intel AGTL+
Width : 64-bit
Version : 1.00
Number of Ports : 4
Multiplier : 3/1x
Width : 64-bit
APIC 1
Version : 2.00
Multiplier : 1/2x
Memory Module 1
Version : 1.2
Memory Module 2
Version : 1.2
Memory Module 3
Version : 1.0
Memory Module 4
Version : 1.0
Version : 12.01
Cooling Device(s)
CPU Fan : 2377rpm
Voltage Sensor(s)
CPU DC Line : 1.17V
Aux DC Line : 3.25V
+5V DC Line : 4.28V
Version : 2.30
Revision : A3
Revision : A3
Sound Adapter 1
Revision : A1
Type : AC '97
USB Controller 1
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 2
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Revision : A3
Version : 2.00
Interface : EHCI
Channels : 6
USB Controller 5
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 6
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 7
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 8
Revision : A3
Version : 2.00
Interface : EHCI
Channels : 6
Revision : M1
Version : 1.10
Interface : OHCI
Channels : 64
Speed : 400MHz
Version : 0.02
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
Port Connector(s)
SATA1 : SATA
SATA2 : SATA
SATA3 : SATA
SATA4 : SATA
F_ESATA : SATA
SATA_E2 : SATA
PRI_IDE : SATA
USB5_6 : USB / USB
USB7_8 : USB / USB
USB9_10 : USB / USB
CPU_FAN : None
PWR_FAN : None
CHA_FAN1 : None
CHA_FAN2 : None
