- Jun 13, 2008
Hi guys...looking to watercool my new rig (first actual WC build). Gonna be like 2 months before I buy everything so I'm doing some research and am looking for some inputs from the experts. Here's what I'm planning to use:
CPU - Intel Core 2 Quad Q9300
MB - ASUS Striker II Extreme
RAM - 2x OCZ Reaper DDR3 1333 PC3 10666
HDD - WD VelociRaptor
VID - 2x ASUS EN8800GTS
SND - SB X-FI XtremeGamer Fatal1ty Pro
PSU - Antec TPQ-850
CASE - Not Sure....open to suggestions...thinking NZXT Tempest or Antec 900
Now at first I'm planning on just a single loop to cool the CPU and NB and just air cooling the 8800GTS's...plans to possibly water cool GPU's if temps aren't where I want them, so I'm gonna post what I plan on using for all of it and then asking for feedback.
CPU BLOCK - D-TEK FuZion V2
PUMP - Swiftech MCP655
RESERVOIR - Dual 5.25" Bay Reservoir
RADIATOR - D-TEK PRO120 with D-TEK Fan Shroud
Tubing will either be 1/2" ID Tygon or 7/16" ID if I can find some good stuff. I would basically just double everything for the WC setup to make the second loop and just use the DD IONE for G92 on both cards. The 2 loops would be CPU/NB on one loop and the 2 8800GTS's on the other loop. Thinking of using the Tempest case and mounting the 2 rads at the top pre-drilled spots. I would like to keep everything inside the case and keep temps as low as possible.
My biggest question is are the 2 Pro-120's enough to keep those loops cool or would I be better off with dual 120's? Also, if you guys have any tips or replacement ideas they would be appreciated. Working on somewhat of a budget and would like to keep costs low in certain areas without cutting quality. Thanks for any help guys.
PSU - Antec TPQ-850
