Hi,
I just bought the parts for my first from scratch build (http://www.overclockers.com/forums/...t-build-ok-quick-info-buying-in-less-than-24h).
r9 290
z97x-gaming3
TS550W XFX
I put everything together, except for graphics card and it booted to bios. But after installing the graphics card the computer does not post, it does not show any signs of life (no lights, no fan, no nothing).
I installed it into the PCI-e x16 slot, connected the power (8pin + 6pin).
Is my card bad (note it seemed as if I received a already opened box, it was not sealed and it seemed used) ?
Thank you for you help
r9 290
z97x-gaming3
TS550W XFX
