unfortunately, there's no way to reduce the amperage for normal 2 or 3 wire fan
the controller for these kind of fans work by reducing voltage supplying to the fan, and according to the "eternal energy law"; we're converting the unwanted voltage to heat.
connecting your 0.6A and 0.7A might be shorting the lifespan of your akasa controller, and you're definitely will having performance impact with your fans on full speed (your Delta won't reach it's maximum RPM)
adding an additional heatsink to the voltage regulator chip might help with the lifespan of your fan controller, but I'm affraid this would be troublesome to do with the Akasa All in One 2 fan controller closed enclosure
in brief, your controller will work, with a slight performance impact to the fans maximum rpm...
and might be shorten its lifespan
p/s
Sidus,
I reposted my PM here on your thread,
hope this might help others with the same issues,
and others can point our if I making any mistake.
cheers
