Hi, Ill be getting a ASUS A7N8X-E DELUXE soon and getting ready to install I got the online manual, but there are couple of things that are not clear that someone here may know. I included pics from manual so its easier.
1) USB connector, my case connectors for USB had these labels on plugs GND, Data-, Data+,VCC+ and a separate 1 pin on same cable labels Shield, does the Shield pin go on the pin labelled NC on the diagram below you think?
2) Header pin, couple of questions on this:
2a) My plugs from case have a triangle on one side and I found out this means '+', on the diagram below the Reset SW and Power SW does not show what side + should go, is ground or GND on those the minus side?
2b) Power SW plug this the same as ATX Power Switch Label? I only ask because the description says:
but I cant see whereelse the Power SW plug goes so must be this mustnt it?
Hopefully be trying to install it Tuesday/Wednesday as my other board went, im hoping my other components still work after my other one went wrong and died, but as i was recently made redundant i think ill try another socket A board before i have to spend out on a new computer.
shirl
shirl
