The following settings were tested with the six memories on the Athlon 64 test bed:
12x200/DDR400 - the highest stock memory speed supported on K8T800/nF3/SiS755 motherboards.
11x218/DDR436 - a ratio near the standard DDR433 speed.
10x240/DDR480 - a ratio near the standard rating of DDR466.
9x267/DDR533 - a standard memory speed used in testing other high-speed memory.
Highest Memory Speed - the highest memory speed that we could achieve regardless of the multiplier. This setting was generally achieved at a 2T command rate and performance is often poorer than slower memory timings at a 1T Command Rate.
Highest Performance - the highest memory performance settings that we could achieve. This setting is normally the highest stable speed using a 1T Command Rate. A couple of the memories tested here were able to run at an incredible 8x300/DDR600 speed. This is the next ratio multiple for 2.4GHz speed and will be added to future memory benchmarks as more memory is able to reach this performance level.
Command Rate is not normally a factor in Intel 478 tests, but it is a major concern in Athlon 64 performance. A Command Rate of 1T is considerably faster on Athlon 64 than a 2T Command Rate. For this reason, we had added the Command Rate to the timings and voltage reported for each memory speed setting.
