- May 22, 2011
- USA
That's horrible. Wonder whats going to happen. Imagine this more common to the masses. AMD's opportunity.....
Nothings going to happen. Remember, enthusiasts are about 1% of the market. Most of these CPU's will only see a stock heatsink. There is no opportunity for AMD for anything here except for maybe learning something at Intel's cost.That's horrible. Wonder whats going to happen. Imagine this more common to the masses. AMD's opportunity.....
Imagine that!What'll hopefully happen is that the cooler manufacturer reimburses the customer for their crap design.
Not gonna happen.What'll hopefully happen is that the cooler manufacturer reimburses the customer for their crap design.
Not gonna happen.
Not gonna happen.
This is the first time I've heard about crushed or bent CPU so this is news to me but have always heard the saying, don't tighten all the way or you'll "crush" the CPU.
The design for AMD's chips in this way is actually superior because it can tolerate more pressure without hurting anything at all.
The method used with an AMD doesn't rely on downward pressure, the CPU pins themselves once the CPU is in the socket goes between a pair of contacts/fingers, closing the lever pushes the CPU "Foward" in the socket causing the pins to move too, this causes the pins to get pushed and wedged between these contacts/fingers.... At least that's a basic way of describing it. Opening the lever merely moves the CPU and pins "Back", pulling the pins out of this wedged effect.
