- Jul 12, 2002
Getting really frustrated here...
I continue to experience intermittent black screen issues with my gpu.
It happened with my Powercolor HD7950, which I'm in the process of RMA'ing for that and another reason...
Now I bought a XFX R9 280 (on Wednesday), it installed fine, no issues, and Saturday I get about 5 black screen issues right after another...screen goes out for 3-5 seconds then comes back. I was playing league of legends.
I tried once again to do a driver reinstall...here's how I install AMD drivers. I'm now trying the newest beta driver from AMD as well as MSI afterburner 3.0 beta 19. I believe all my MSI afterburner settings are correct, disable ulps etc...
How I Remove AMD Drivers:
1. Access Add/Remove Programs via the Windows Control Panel
2. Double Click “AMD Catalyst Install Manager”
3. Use the Express Uninstall Option
4. Reboot after the uninstall process has completed
Remove left over files/folders:
1. Access Folder Options from Windows Control Panel
2. Click the view tab and select “Show hidden files/ folders and drives (Apply Settings)
3. Access Drive “C” (Or wherever your OS is installed)
4. Delete the folder named “AMD”
5. Go to “Program Files” and delete all AMD / ATi associated folders
6. Go to “Program Files (x86)” and delete all AMD / ATi associated folders
7. Go to “ProgramData” and delete all AMD / ATi associated folders
8. Go to “Users\YourUserName\AppData\Local” and delete all AMD / ATi associated folders
9. Go to “Users\YourUserName\AppData\Roaming” and delete all AMD / ATi associated folders
Remove left over registry entries:
1. Access ‘Regedit’ (This can be found in Administrative Tools or by Windows Search)
Please Note: We will be using the left side panel within ‘regedit’ during this tutorial
2. Click “HKEY_CURRENT_USER” and extend the folder
3. Click “Software” and extend the folder
4. Delete AMD/ATI associated folders
5. Click “HKEY_LOCAL_MACHINE” and extend the folder
6. Click “SOFTWARE” and extend the folder
7. Delete AMD/ATI associated folders
8. Click “Wow6432Node” and extend the folder
9. Delete AMD/ATI associated folders
10. Click “HKEY_USERS” and extend the folder
11. Click “.DEFAULT” and extend the folder
12. Click “Software” and extend the folder
13. Delete AMD/ATI associated folders
14. Click “S-1-5-18” and extend the folder
15. Click “Software” and extend the folder
16. Delete AMD/ATI associated folders
17. Feel free to check the remaining “S-1-5” / “Software” folders for AMD / ATI folders (and remove them)
18. Close ‘regedit’ and empty your recycle bin, followed by a reboot
I've tested my PSU, it's fine, I'm not sure if I'm just unlucky or if I'm doing something wrong? Could the dozen driver install/reinstalls be causing this?
My system is not overclocked, no heat issues, clean, good cooling…
Before I return this XFX card to the store on Monday I'd like to see if I can figure it out.
No I don’t have another system to try this in and like I said, it could be days before I’d see another black screen pop up.
Thanks.
Thanks.
