* [Always boot into Windows 8 Desktop, bypassing Windows 8 Metro:]
Right-click on the lower left corner > Click on the yellow File Explorer icon > View > Options > View TAB > SELECT: Show hidden files, folders, and drives and UNCHECK: Hide extensions for known file types > OK > Now go to Computer > C Drive > Windows > Right click on empty space > New > Text document > name the file NoMetro > Open it in Notepad and enter the following:
[Shell]
Command=2
IconFile=Explorer.exe,3
[Taskbar]
Command=ToggleDesktop
File > Save > Rename the file's extension to .scf so the file is now called NoMetro.scf (even if .scf extension is not visible)
Right-click on the lower left corner > Run > control schedtasks
Task Scheduler Library > Create Task… (upper right) > Name: NoMetro > Triggers TAB > New… > Drop down menu > At log on > OK >
Actions TAB > New... > Browse to C:\Windows\NoMetro.scf you created above (even if .scf extension is not visible) > Open > OK > OK
