I can definitely get Crucial Ballistix PC2-8500, but maybe not Crucial Ballistix PC2-6400. Was it the PC2-6400 or the PC2-8500 Crucial Ballistix that was da bomb. Could it even be possible the PC2-8500 wouldn`t do what the PC2-6400 does. Running 1:1 with 1333 XX50 with 400 OC`d up a chunk. cas4 I think is true (yes, yes, yes) at this setting with at least one of these. Can you tell me which, or bothÉ The specific IC chips are important, and I don`t think I have those links right here___, telling me what each use(s) or use(d). Ballistix is Micron, don`t know if both are `fatbody`. I`ll be looking. Can ANYBODY answer that, and only that for me in the mean time.
BUYING A NEW RIG:
I am gonna get a C2D 2 core E6750 or E6850 with latest 1333 w/ 333 cpu and put it in a P35 mobo, Asus P5K, or Gb P35-DS3R, or o/?. Both should be able to do a 40% overclock. Settled. 2.6GHz to 3.6GHz, or 3.0 GHz to 4.0GHz, on air, quiet. I'll tune down for low noise/heat: to what, I dunno.
Hundreds of reviews later I have come to a RAM decision, sort of. I decided I don't want to buy a RAM knowing first off it will be the limiting component when I begin to OC. OCZ Platinum XTC Rev.2 PC2-6400 DDR2-800, and other OCZ RAM, is on sale now everywhere for about $58 for a 2x1GB kit, after $40 mail in rebate avail for another week. I asked OCZ forum if it could hit these speeds at 1:1. They said the 400 is ok, just don't expect to oc, and it'll be working hard. If you want to oc, get a PC2-8500, or better, RAM. Why the heck would I want to spend more so I can do the exact same thing, run at 1:1 at 400 (thats a nice little speed boost in itself), just for a few % more total oc.
I said why, its a top end OCZ product, its gotta have a little oc heardroom, why can't it do what I want, becasue it ain't 10x the price? The I thought OCZ are not saints, they put the top end product label on it, but it ain't top end, not like it could be/ has been. Its a ProMos IC. Then I thought about it, it has 3 SPD tables for 266, 333, and 400. The one setting I want, 1:1 at 400 (for any RAM I buy), is the hardest for this product to do. For a higher rated PC2-8500 or better RAM, this would be easier to do. Therefore, it is more likely to have a little headroom. Not to mention, thereoretically easier for better timings, no matter how you look at it. Does this make senseÉ
Then I see the headlines of the day, latest DDR3 2 $800 2GB kit is hitting 1600 at cas7. But the RAM I want for $58 I want to oc above 1600 right outta the box, hopefully cas4. Maybe DDR3 is in its infancy. I hope the RAM I choose CAN do the above with the new 1333cpu I am getting, as I am expecting!!
Reviews with the 1333 XX50 cpus and DDR2 thats been out for a while are hard to come by and I have to walk into a store in Toronto, no mail order. I have determined the Patriot is good PDC22G6400LLK(1st best), Crucial is good TWIN2X2048-6400C4 (2nd best), OCZ is 3rd OCZ2P8002GK. Maybe all do what I want, dunno, that was the intention of this list. There are slightly different model variations, I have just tried to ensure I can get the 400 vs 333, and get it up into the decency level of oc speak. PC2-1000 has slipped my research. And of course I have to deal with the fact that a lot of the reviews which give me this knowledge are reaching 1040, better than 1000 is my minimum goal, sort of in this roundup. What has this got to do with 400/1600, something I have been told a $58 RAM can do, anything. Sorry my question mark key isn`t working.
So Crucial Ballistix never had anything bad said about it, and I think it is above all those others, even though I am not sure if I need better than any or all of those others. It if any could do it all, it would not be limiting. I can get Crucial Ballistix PC2-8500 (BL2KIT12864AA1065) for about 170 dollars (all keys gooning some). And Crucial Ballistix Tracer (BL2KIT12864AL1065) for $177. In case of in-stock situations, is the tracer as good, for meÉ
So, for $58 for RAM, and about $143 for a P5K, and $203 for an E6750 you`re in 2.66GHz*400/333=about 3.2GHz I believe, which ain`t bad.Even save $25 if go for P4K SE without chipset heatpipe, but as OCZ said in their forum, the RAM may be working hard, so I dunno if thats a good idea. P5K with Ballistix is vs SE with Rev.2 $128, more. For what, I dunno exactly. I`m not even sure if 400 at 1:1 is 2.66GHz*400/333=about 3.2GHz, since ?1000 keeps popping into the picture.
BUYING A NEW RIG:
