- Thread Starter
- #21
P95 Blend mode which I think everyone of us uses is a far more robust test than AOD test. That means if they all feel you are already too hot with that AOD clock you have, then you are certainly too hot to run P95 Blend as a stress marker. What really is showing to us, is the AOD is fooling you into thinking your speeds might be workable.
If you want to use AOD, then do it. Just we cannot help with that software clocker when you are aleady beyond the temps that have been known to be unstable. The testing and using of course are up to you.
RGone...
I am doing a Blend mode right now with the 120mm fan in the top on medium speed. max temp this far (test 11 now ) is 49C and i run on 19x at 4118mhz and 1,44volt
The AMD overide did not save the overclock settings and i gues thats why you guys want me to lern the BIOS so the work will be for real! And i will give it a try with a good guide
