- Jan 10, 2012
you know we really need to go over to the motherboard section and have a triple throwdown brawl and answer this highend cpu/lowend board thing once and for all.
You'd do fine with them but I'll try to keep it simple.
The 6300 is a nice chip, think of it as your chip but having 2 additional cores and slightly (~15%) better performance per core at any given speed and it does so on about the same amount of power as you use now.
More recent/well-made games will perform well on it, the more cores they use the better off you will usually be(assuming they are used well).
What you lose by not going Intel is performance per core. Simply put, there are times when the Intel processor will offer roughly 30-70% better performance per core at similar frequencies to the 6300. Got a game like Skyrim/World of Tanks/Company of Heroes? Those tend to do wayyy better on Intel because they aren't using many cores BUT they are also CPU bottlenecked with most current gaming quality video cards.
With that board you will be able to overclock that chip a long way, so if you grab that setup and a good processor heatsink then you can aim for a nice overclock and it will be a really nice upgrade.
Edit: I'll give you an idea. In Company of Heroes last night I was playing with 1 friend using an fx-6100(stock), 1 friend using an i5 3570(stock) and myself on a 1045T(3.7GHz). At the end of the game it reported our average FPS...the Intel set 37FPS, my 1045T set 18.5 and the 6100 set 13. Because the game uses 1 core the only way to get something smooth is Intel. Alternatively, we all get visually similar FPS in BF3(usually 50 or above) though if we all run stock CPU the 3570 is still a bit ahead. So sometimes the difference is tiny, sometimes the difference can be huge.
It's what happened to me. When I got into custom PCs, my friend that got me started was/is an AMD fanboy. Hence, I have a 1090T. I'd absolutely kill to be on an Intel upgrade path.That sir is a great way to make suggestions. No fan boy shett. Even-handed handling of the constant Intel vs AMD bickering and on top of all that wording that makes freeken sense. Congratulations to you sir.
I have not recommended anything but Intel to GAMER buddies in 2 years. For about the very same reasons you state. Now when there were some good Thuban 1090T and 1100Ts available and money was 'bad tight', we could deal with AMD to an extent and do pretty good.
BUT when AMD dried up the good BE type Thubans to force everyone to FX-BS or was that FX-BD. Hehehe. Then I had to strongly urge a middle of the road Intel setup for pretty good success in 'all' games. The game used makes a pretty good diffrerence in one's results as you have stated.
Now in my mind if one I have need to make a gaming rig suggestion comes along and money is tight...well the FX-6300 and a board with at least 6+2 VRMs can fill the bill fairly effectively >> still money no object for play of any type game...Intel is my suggestion to them. Those just seem to be a set of facts. Mileages may vary. Success stories from both sides may be everywhere, but the law of averages seems to point at any game get Intel but expect to pay a little more overall. RGone...
Did I say I am very happy with my FX-8350 on CHV board and do not game but do editting of home videos regular. So it is what and how a rig is used that makes the specs so critical. RGone...again.
Now I have 2 generation old hardware and can't afford a serious upgrade to IB. Oh well, live and learn.
Welp, woke up in the morning to see all these replies! I am well certained that I will get the i5 build, it just seems better and I probably won't have to upgrade parts for another 2 years or so.
