Make sure its got enough power. nVidia cards will run super-slow if they don't get enough juice (if this is the case, when 3DM06 starts running, your first thought should be "WTF? Why is this running so slowly?").
Whats up with you're vcore? Your load numbers are significantly lower than your idle numbers, which are also significantly lower than your settings. Bad sign...what's your hardware setup?
