As I pointed out earlier, I said DDR500, DDR550 means trying to get memory modules that can run 250 - 300 MHz. It does not refer to DDR500 (PC4000) literally.
The DRAM chips used in each memory module are more important than the rating such as PC4000.
For 3200+ with x10 multiplier, you will get memory bus equal to CPU/10 (at 1:1 ratio) or CPU/12 (at 5:6 ratio).
For 1:1 memory:FSB ratio,
memory_bus_frequency = CPU/10
so if CPU = 2.5 GHz, memory_bus = 250 MHz.
PC3200, even for BH-5, would be hard to run at 250 MHz without a Vdimm mod using 3.0-3.3 V.
Generic PC4000 is rated to run at 250 MHz, but the latency may not be as good as EB. As many has pointed out, the EB modules will enable high memory bus 250+ MHz at small equivalent latency. You have to make your decision based on your budget.
Or get some modules that use the same DRAM chips as EB.
