- Oct 3, 2013
- UK
Hi,
I am new to the forum and new to overclocking!
I have just upgraded my PC with a Gigabate Z77 mobo, and a i5-3570k CPU.
I am not sure about the cooler that suits my need.
Basically I intend to clock the CPU up-to 4.2GHz max.
I did a little research and i think the NOCTUA U14S seems the righ cooler for my needs. The only concern i have is the size of the fan,
The system fan on the case is a 120mm. The one on the cooler is 140mm.
So, does it mean that the case opening is too small for the cooler's fan to be effective?
If so, should i opt for the smaller NOCTUA 12S?
What do you think?
Thanks in advance.
What do you think?
Thanks in advance.
