- Jul 12, 2002
Hey Guys,
Soon I'll be upgrading my system from what you see in my tag.
The plan is to get a Gigabyte Z87X UD3H with a i7k, not sure which yet, prices are pretty high...maybe settle for a i5k..
My question is this...
What do you think about my current HS? The Thermalright 120 I'm using? I know there's a adapter bracket I can buy for it so it fits the 1150 sockets. I'm also not sure if the HS fins degrade over time from heat?
I also am aware of the Noctua NH-D14 120mm & 140mm SSO CPU Cooler and Thermalright Silver Arrow SB-E Edition which is difficult to get in Canada but if I don't have to spend the money then why bother?
I'm looking for a moderate Overclock (air cooled only), nothing crazy...currently I've been OC'ng my C2D 6400 2.13ghz stock at maximum 3.2ghz stable for over 6+ years...now I just have it at 2.8ghz...
So if I buy a k series i5 or i7 that kicks out stock 3.4-3.5ghz...I'd like to get a 4.5ghz OC on the chip. My main goal in an OC that is stable is low temps...I have yet to research what temps these chips kick out and what is safe etc..
Thanks.
Thanks.
