I'm helping a friend by phone troubleshoot her first build of a PC, so I have sort of limited access to the machine. Her build is:
MSI KM4AM-L KM400A
Duron 1.2 GHZ
1 x Crucial 256MB PC-2700 4-T
Antec 300W(SLK300S)Smart Power PSU
From a cold start up, the system starts, displays AMD Duron at 1200 MHZ, and then offers the option to setup or skip setup (uses Phoenix bios). But within a few seconds of entering the bios (not long enough to check cpu temp), it shuts off. If restarted almost immediately, it shutsdown even sooner or doesn't turn on at all.
The jumper for the FSB on the board has been properly set to 100MHZ. There are no drives connected (although it has been tried with the floppy--same results). To me, this sounds like the CPU is overheating. I do know that the CPU works--it came from an older, working system.
Also, and perhaps this is related, she did have all of the jumpers pulled off the FSB jumper pins the first time she tried to boot (sigh). CMOS was cleared once this problem was corrected. From looking at the motherboard manual pin settings, it's possible that no jumper pins would have set it at 200MHZ FSB, so perhaps the CPU was damaged (although, then it should not start at all, should it?).
She' starting to get very discouraged, so I want to be sure to take the most liklely direction of attack for diagnosing the problem. Any suggestions or thoughts before I have her clean the CPU grease and reseat the heatsink? Is it more likely a bad motherboard or RAM?
MSI KM4AM-L KM400A
Duron 1.2 GHZ
