- Jun 11, 2009
This is what I bought so far.
(1) Cooler Master Cosmos-s case and side window option
(1) Danger Den DD-GTX295 VGA Full Card Liquid Cooling Block (GPU-6850)
Selected Options
Select G 1/4" Fittings (Qty. 2): 3/8" ID Compression Fitting
(1) 620 Swiftech Apogee™ GTZ i7 CPU Waterblock - Socket LGA 1366
(1) XSPC RX360 Triple 120mm Radiator
Selected Options
(1) Danger Den Black Ice Xtreme 120mm Radiator (Black)
Selected Options
(1) Swiftech MCRES Micro Rev. 2 Small Form Factor / High-Flow Reservoir (1/2" ID & 3/8" ID)
(1) Swiftech MCP655-B™ 12v Water Pump w/ 3/8" Conversion Kit (317 GPH)95
(4) Scythe S-FLEX™ SFF21D 120 x 120 x 25 mm Fan w/ S-FDB Bearing
(1) PrimoChill PrimoFlex PRO LRT Tubing 3/8"ID 1/2" OD with 1/16" Wall - UV
(3) Primochill 3/8" UV Reactive Leakproof T Fitting - UV Red
(3) Primochill 3/8" UV Reactive Leakproof Y Fitting - UV Red
(14) 1/2" OD Reusable Clamp - Black
(2) Koolance 3/8" (10mm) ID Tubing Wrap - Black (SPR-10BK)
(4) Bitspower Ultimate G 1/4 Thread 3/8" ID x 1/2" OD Compression Fitting
Thinking about adding this chipset water block.
http://www.frozencpu.com/products/8...uid_Cooling_Block_CHP-325.html?tl=g30c313s858
Will I need the 2nd Rad and if so where would you put it in the loop? Also I didn't get a fan controller and coolant temp monitor. Do I really need them and if so what whold you suggest.
Thanks for your opinions.
Selected Options
Selected Options
Selected Options
