Is This System Ok To Overclock?
Elluzion
[NorCal]
Here is everything i'm going to get, if you think i should change anything, let me know. i am getting all my parts off of newegg.com
i'm building a pc for my senior project, wanted to know if this would overclock with ease. maybe to like 3ghz or more. would the heatsink keep it cool enough? any suggestions???? THanks! and yes i am new to this stuff
CASE:
APEVIA X-CRUISER-BK Black Steel ATX Mid Tower Computer Case - Retail
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16811144151
POWER SUPPLY:
Rosewill Stallion Series RD500-2-DB ATX V2.2 500W Dual 8cm Ball Bearing Fan Power Supply 115/230 V UL, CSA, TUV, FCC - Retao;
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16817182044
MOTHERBOARD:
GIGABYTE GA-P35C-DS3R LGA 775 Intel P35 ATX Intel Motherboard - Retail
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16813128048
CPU:
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor - Retail
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16819115003
HEATSINK:
ZALMAN CNPS9500 LED 92mm 2 Ball Cooling Fan with Heatsink - Retail
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16835118223
MEMORY:
OCZ Technology, Inc. News Room
OCZ 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16820227181
HARD DRIVE:
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16822148140
CD/DVD WRITER:
Need Suggestions
GFX CARD:
EVGA 256-P2-N615-TX GeForce 7600GT 256MB 128-bit GDDR3 PCI Express x16 Video Card - Retail
Code:
http://www.newegg.com/Product/Product.asp?item=N82E16814130062
(TOTAL: $884 w/o Tax & Shipping)
I had a Zalman 9500 and although it was OK there are much better coolers out there for not much more. Try looking into a Thermalright Ultra-120 or the extreme, or a Tuniq Tower.
ok i will look into a better heatsink.
also do you think that my mobo is overclock friendly? because that is the key. or should i invest in a better mobo? if so which one? (one that supports the intel core duo)
CHECK THIS SITE OUT:
which one of these would be the best to get to keep me cool for overclocking?
http://www.newegg.com/Store/Category.aspx?Category=11&name=Fans-Heatsinks
if I have all the fans and stuff for the computer and i put a heatstink on the cpu, will my computer be ok to clock
thanks for the help. IS MY MOTHERBOARD OK TO OVERCLOCK, WILL IT WORK fine? or do i have to invest more into my mother board? check the parts i am going to buy above
OH AND ALSO: what is the temp that i should not exceed when overclocking the core 2 duo (2.4ghz) should i keep it under 60c? or is it different for what im getting?????
Thank you soo much please answer all my questions
Yes, the motherboard is fine. Yes, the general rule of thumb is to keep load CPU temp below 60 if possible.
I would get a better power supply. That Rosewill you picked is totally inadequate. Very low amps on the 12v rails. Get the Corsair 620HX or this Silverstone (see link).
http://www.newegg.com/Product/Product.aspx?Item=N82E16817163111
I know it cost a lot more, so let me suggest getting the cheaper E6420 Core 2 Duo. It is the best bang for the buck. It's do an easy 3.2 gig with decent cooling and low voltage. Most will do more than that even.
Also, the RAM you picked, while good, is sort of overkill and expensive. Get either the G. Skill "PK" (first link) or G. Skill "HZ" (second link). I have 2 buddies that own the RAM in the first link. They rock and will do DDR2-900 easy with modest voltage and 4-4-4-10 timings.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231087
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231065
thanks for the suggestions, yeah i didnt think that the power supply that i was getting was adequete. thanks for catching that. also the e660 is only 40 dollars more so i am just going to get that. also im not sure about the ram yet, but might keep the one that i have. do you see any problems with the compatability of anything? or anything else that I should change?
so the better power supply i have the easier and safer it will be to overclock? same with heatsink right?
I would recommend also waiting until July 22nd to buy your stuff since the CPU will drop significantly and you will be able to get CPUs which OC much better for similar price of the current 6600.
Yeah, if you get a better PSU, the rest is ok. But, most of E6420 processors are overclocking as high as the E6600. Not sure why you want that RAM. Let's do the math with an E6600. Mine does 3.6 gig stable. That's 400 FSB or DDR2-800 with the 1:1 memory ratio. PC2-8500 will handle 533 FSB (DDR2-1066), which is way more than you'll ever need with either E6600 or E6420.
^yeah true. i will get the ram that you said to get. yeah it is a much better deal and stuff.. thanks, yeah it'll be past july 22 anyways. we'll see what comes out
Them man does speak with some sense. Listen to him.
yes i realize it i know. i went with the ram that you picked out, it will work fine. and i will wait to see the price drops on the cpu's after july 22nd... how does the rest of my setup look? like my motherboard? will it stand overclocking?
