- Dec 18, 2000
- Peoria Ill
I recently built myself a new computer. Since I have been working with computers supplied by my employer(s) the last 15 years or so, I havent actually tried to overclock much since I replaced my 8088 chip with a NEC v20 to go from 4.7mhz to a blazing 5mhz ! I have been working building servers, programming and doing network administration for years, so I have a vague idea of what I am doing.
Back to the present:
I have the following installed in a big Enlighten ATX case, 800EB, 256mb PC133 RAM, ATI Magnum Xpert 2000 graphics card. Added 2 extra 80mm fans and drilled out the holes in the front of the case some to increase air flow. (This lowered the board temp reported by CPU cool from 33c to about 24-25c ave.)
Is stable as a rock at 800mhz 133. Got a fairly big performance boost by setting the memory to turbo and CAS2 in the BIOS. See attached memory benchmark from Sandra. In spite of some reviews of the VT6X4 I read that said it had some problems with memory bandwith, my system seems to be doing OK. The CPU benchmark lands right where you would expect for 800mhz.
Unless I am mistaken, feel free to let me know if I am, the only OC options for this CPU will be to try 140 or 150 fsb speeds to get to 840 or 900mhz.
When I try this, the computer is stable in DOS. Can run DOOM or Redneck Rampage with no problems, but when I go into windows with the higher FSB, I get various invalid instruction errors, page faults ect.
I attempted to turn the DRAM clock to HOST-PC, but the errors still occur, so I don't think it is my RAM. (It seems it would be pointless to reduce memory performance by 20% to boost CPU speed 5% it that was the case anyway.)
I suspect the problem is either voltage related, or with my ATI graphics card. (2xAGP, 32mb)
At the moment, I am back down to 800mhz and 133fsb, but I have left the voltage at 1.7 up from the default of 1.65. Will this help to maybe "burn in" this thing a bit and perhaps make it more stable at 140/150 fsb ? **Caution to any of you playing with this VT6X4 motherboard. When I went to set the BIOS settings back to default, the CPU Core voltage was flipping to 2.05 when I selected CPU default. Had to leave it at User Setting to stay at 1.65/1.7 !
Any suggestions on how to get stable at higher fsb with this setup would be appreciated.
6502kid
6502kid
