Lark-ICE- said:
here's what i have so far
D-TEK FuZion Universal CPU Waterblock $65
Black ICE Pro II Radiator $35
DD12V-D5 Pump Variable Speed $90
NEXUS REAL SILENT CASE FAN D12SL-12 X2 $30
Tubing $10
Coolant $20
Total $250
Few things:
-With quiet fans a MCR-220 or GT Stealth 240 would be more effective, but that isn't that big of a deal if you are looking to save the money.
-That D5 pump is going to be annoying if you are sensitive about noise, and will well outstep the noise of those 120's, also $90 is an insane price for that pump. As posted before I would recommend a DDC-2 or DDC-1 (Quieter but sighly less performance.) Many of the mod shops sell replacement tops that vastly improve the performance of these pumps, and allow them to be used in 1/2" ID loops.
This is the pump, the DDC-2 model, what I did was grab one for a good deal used from the classifieds and then bought
this top. The other popular top is from Alphacool, which looks like
this. Of course you can save yourself some money and follow some of the guides to making your own top if you really wanna get into modding.
-Those nexus fans are basically rebadged Yate Loons, and are so similar that its sort of silly to buy them at 15 bucks a pop, especially when they can be had for $3.40 each. The model number is the same but the manufacturer is "Yate Loon"
-Hit up your local auto parts store and get a small thing of antifreeze, I use pentosin G11. This should be cheap as you wont need much, I've had this 1.5 liter bottle through 4 or 5 drains and I'm not even halfway through it. I would suggest also that you stop by a aquarium supply or pet store and get some algaecide, a few drops of that and a 5% or 10% addition of antifreeze with grocery store distilled is all you will need, much less than $20 total.
