Hello.
First my pc.I have Gigabyte Rtx 3090 OC ( stock ) and 10850K stock ,32gb ram.
Issue is only on 1920x1080P with 165hz. On 1440P with 165mhz is fine. On 1920x1080P with 144hz is fine. On 1920x1080P with 165mhz i can see on screen small black dots flickering vertical.
If i wanna catch screen its not visible or clip. So i post screen and i added from paint. Just very small flickering black dots on vertical position. Happens only in 1080P with 165HZ. Visible on desktop too when i am very close.
When i made perform scaling on [gpu] in nvidia panel that line of small dots/squares will dissapear.
https://i.ibb.co/QJCTh7B/art.jpg
somebody ( other person ) had the same issue with same monitor,link reddit:
It happens only in 1080P or below with 165hz. With 144hz 1080P is ok. 1440P 165hz its ok. Even on 1920x1200 165 hz its ok.
Just problem is on 1920x1080P 165hz.
I am not happy with pc because of this. What should i do ? Ignore that or rma ? Somebody said that i must rma monitor even if doing that on non-native resolution. Or maybe its hardware issue?
