I'm using an ivy bridge 3570k in an asus sabertooth z77, I overclocked to 46x100 and it was stable under a 12 hour prime95 torture test at 1.290v (Quite a bit higher than everyone else, apparently I have a fairly low quality CPU)
I just had a system freeze at 1.32v - I've been upping it by 0.005v every time I got a freeze assuming prime just hadn't caught the instability.
Since I'm now well above the point of "Stability" I'm assuming either I missed a setting somewhere or it's something else entirely.
I still presume it's an overclocking issue because lowering the vcore back to 1.290v makes it usually freeze before ever hitting the log in screen while higher vcores last longer (But still fairly randomly crash) and going back to stock speed I don't see any crashes.
Edit: Just got it to boot at 1.29v but I doubt it will last long, could this be caused by "Droop"?
This is my first overclock so all I've tweaked is the multiplier, the vcore, and set the vcore to fixed.
PS: I'm on linux (No idea if that little tidbit will start a flame war but I'm hoping not - I just want to get my hardware stable)
Edit: I just realised I only benched small FFTs (prime torture test default) - Lets mark this closed, I'll leave a result once I get it blend stable
Edit: Yep - seems stable at 1.335v with "Ultra high" LLC so it's about 1.34v
