Yeah, so 200Mhz overclock.3570K not 3770K i use.
Well first time builder here, and after stress testing a 3570k at stock settings, I'm a bit concerned about the temps at full load, I'm starting to suspect i may have to re-seat the cpu cooler and re-apply the thermal paste.. or invest in a better cpu cooler, the cooler I currently use is a COOLER MASTER Hyper N 520 with Artic Silver 5
My first impression is that IB overclock and temps seem okay for daily type useage. Booted into windows at 45x and then decided to test 46x which was a common 24/7 "crunching" overclock for me with SB cpus. Vcore set to 1.35v in BIOS with vdroop enabled (my combo droops to ~1.25v load) also running on die graphics with a voltage bump at 1.3v... all other voltages at default and dram at 1.5v. Cooling is under water via XSPC RX240 on an open air bench. Ambient temp is ~21.5C. Batch#3208C060
Got the 3570K today and the system too. Not sure why the 3770K is out of stock everywhere. I think the 3570K is the better deal for most gamers when it truly can OC so easely and save up over 100$ which can be invested into a even better GPU = more value. Although i still miss the OS and the G.Skill RAM, so i will have to wait.with less heat, so even if it can't muster a 200MHz OC on stock you can up the voltage a bump and still have less heat than a 3770K.
those are amazing temps for IB
Besides, the picture from PolRoger is probably fake. The difference between Idle and Load is 10 Cdifference at that picture which is kinda unrealistic. I know how much of difference those different conditions can create, even on water cooling it should be much higher. Even the specified 1.3 V is fake because in fact the picture is showing us 1.25V, so i dunno but its not very trusted. Actually 44 C is a lot for water at Idle, but 54 C just to low in order to tackle a fully pushed and OC IB CPU. Kinda looks like air cooling and a very low load. I mean its not the first test i did using such tools, and i had completly different numbers (on air), the temp difference can be as high as 35°. Whats very important is to make a sensor movement test, it should react very clear to the different conditions. When it does make as good as no movement, something seems to be foul.
I've started playing around with my 3770K. I'm not sure how to interpret my results so far. I've reduced dynamic voltage by 0.015V (my understanding is that this constantly subtracts 15 mV from Vcore), and it seems to be stable at 44x. Temps are still very high though--one core is maxing out at 85C in P95 while the others are around 80C. I'm confused by the Hardware Monitor and CPU-Z readings for Vcore though. HM shows 1.07V, while CPU-Z shows 1.188V. Can someone explain this? Based on what I'm seeing, it seems my chip can overclock pretty well at low voltages, but temps are very high. Am I missing something?
I realize this, but relative to other results in this thread my temperatures seem high considering I am undervolting. I asked questions about the Vcore readings because I'm wondering if the dynamic voltage setting in the BIOS is actually doing anything. My temps don't seem to change much going from +0.001V to -0.0015V.IVB is hot by definition.
