You cannot leave E and I static and raise R. It violates ohm's law.
Raising R drops I. Really, really, really basic electrical theory here.
If at max load it has a constant current and constant voltage it has a constant resistance as well.
Please read about the relationship between resistance and current. Start here:
http://www.allaboutcircuits.com/vol_1/chpt_2/1.html
Try it.
Raising resistance lowers current. To be really specific, it's a linear relationship.
Twice the resistance = half the current.
You're continuing to calculate as if current were fixed with a varying resistance. It is not, it varies with resistance.
As far as IB goes, I read it as it leaks like crazy and draws more current for a given
voltage level.
That is the behavior of
lower resistance. Lower resistance with static voltage always equals more current and more wattage used.
Watts = power.
They don't use less power and generate the same power, heh.
They use the
same power, and run hotter.
That is very, very, very different.
Heat is related to power, but different.
For example, 95w into a penny will result in a very hot penny very quickly.
95w into a 200lb lump of the same material will take an awfully long time to get hot.
The IB die is smaller, it has less surface area to get rid of the power. As such it runs hotter for a given amount of wattage consumed.
That fits with thermodynamic and electrical laws.
