- Aug 27, 2003
- Mississauga, Ontario
AMD guy here, just so we get that out of the way..
Every generation of cpus, there are 2 or 3 coolers that ocforums overwhelmingly supports for their price/performance ratio and ability.
I was just wondering, since I already have my 1090T here, and the GB UD5 board is on the way, what are the 2 or 3 favorites among air cooling enthusiasts here? I heard about the Ninja, and someone mentioned something about a Thermalright Ultra-120 etc.
I will be using the Antec 300 case, and will be using two mem slots only, the two recommended by GB to get high OC (3 and 4 I think) 2x4gb. I will be using one pci-e card, high end, if any of this matters, I am telling you because of fit.
Anyhow, what are the favs in the mid price range (like the XP90C was one of the favs back in the days of the rig in my sig) that can handle an 4GHz+ O/C of a 1090T with good case-air-flow to go with it (Antec 300 is awesome for air-flow, I will have two 120mm intakes in the front, and one rear 120mm exhaust and one top 38mm high cfm (They are all high silverstone FM12x series fans) exhaust).
I just saw a simple test that compared a stock cooler/fan with the Ultra-120 at stock speeds (no o/c) of the 1090T (3.2GHz right?), and the stock was (idle/load) 35C/55C for stock, and 31C/41C for the Ultra, so obviously I will be upgrading cooling as I build my rig, I won't even try the stock.
