9mmCensor
Disabled
- Oct 23, 2003
- Banned Camp
hahaEl<(')>Maxi said:
I love that hatchet.
Use it to help presaude your chip to oc higher?
-34 in BIOS is good, the container temp is likely at -65 or so. The BIOS temp is alot different that the point where the mousepot touches the CPU. When my SS is at -50 (evap), my BIOS reports about -24.Gautam said:-34 C is far too high for dry ice.
Have you tried running the RAM at low speeds to see if it is cold bug? The colder you go, the weaker you have to set drive str.El<(')>Maxi said:Damn, well I couldn't get this 57 more stable than on the single stage. I suppose this means I need to pop the IHS, and I'm not in a big hurry to try that just yet. Or it could be not the best contact although I can't see how that possible. I didn't even use the springs with the mounting and it was very tight.
I also ended up with the pot frozen to the board lol, and believe me I had it setup very well. I need to figure out a way to seal the bottom of the insulation where it sits on the mobo. Had some nice temps tho, -34° BIOS, 9° colder than the Baker cooler
9mmCensor said:haha
Cold bug for an FX-57 will kick in usually @ -60 to -80. The first thing that will happen is your RAM will become unstable at the speeds it can usually run. I am thinking you are starting to hit the edge of the cold bug line and you will have to reduce your RAM speed and/or drive strength a bit.El<(')>Maxi said:Well those are some good idea's donko, I have not tried lower drive strengths or ram frequencies yet. I was trying lower Mhz only. All the other guys using this container over at XS didn't have to drop Ram speeds so I figured I was good. Next time I will use a different approach. I would be interested in hearing anything further about Drive Strength and how it works if anyone knows about that.
Gautam donkey is right, I was mentioning BIOS temps only. The container is about -67° when the system is running so about 8-9 degree's colder than single stage.
Eldonko said:Cold bug for an FX-57 will kick in usually @ -60 to -80. The first thing that will happen is your RAM will become unstable at the speeds it can usually run. I am thinking you are starting to hit the edge of the cold bug line and you will have to reduce your RAM speed and/or drive strength a bit.
For temps and mem drive strength, it basically works like this:
The colder the CPU gets, the more you are driving the memory controller (drive str increases). When the mem controller drive gets too high, you get instability. Setting drive strength to weak compensates for the high mem controller strength due to cold to an extent.
Hope this helps!
Using weak drive strength does not affect performance, only stability. Some CPUs are fine with dice, some are better with SS depending on where your cold bug kicks in. Ideally you want to get your CPU to the temp right before cold bug so you can keep your RAM clocks they way you want with the coldest possible temp.Pf.Farnsworth said:do all these factors you have to lower in order to cool lower and oc the prosessor higher really worth it preformance wise? I mean even though you took your FX to 4GHz, overall with all these other components tunned down, does the system preform better then perhaps at a slightly lower cpu clock but faster ram speeds etc.
El<(')>Maxi
EMC2
There are two drive strengths... what are typically called DRAM Drive Strength (or sometimes simply Drive Strength ) and Data Drive Strength.
They control the drive strength of two seperate groups of signals to/from the memory.
Drive strength itself has nothing to do per say with the actual voltage levels of the signals. What it controls is the slew rate of the signals - i.e. how much current is available to drive the signals from one state to the other (high-to-low or low-to-high).
Too weak of a drive strength limits your max OC because it takes longer for the signals to transition (change) from one state to another.
Too strong of a drive strength can cause ringing and signal reflections, which means it will take longer before the signals stabilize after a transition, which again limits your max OC.
There are also other factors that come into play (like termination resistor values, the structure of the output drivers in the memory chips, etc.) that determine the best drive strength for a particular setup.
In regards to what the numbers indicate in regards to slewrates - varies by MB... but for the DFI nF4, Bigtoe's info in the thread you linked tells you the answer in regards to which numbers are stronger and which are weaker drive strengths.
El<(')>Maxi said:Gautam donkey is right, I was mentioning BIOS temps only. The container is about -67° when the system is running so about 8-9 degree's colder than single stage.
That's what I was gonna ask! That's some strong temps...Thats crazy, what kind of single stage is that?
You found an FX that can function with LN2? It's a 130nm I assume?El<(')>Maxi said:It's a Baker unit running R22 on a 1HP rotary. As far as BIOS temps go, I really dont think an A64 on NF4 has a limit.
Exibit A - FX55-LN2-DFI NF4
