- Feb 17, 2012
- Sammamish, WA
Yeah, I know you've never read a thread like this before.
I've read Hokie's "Beginner's Guide to Water Cooling" (took me two weeks but I got through it) and want to take the plunge. The main reason I'm thinking of doing this is not so I can push my chip any harder but rather to try to greatly reduce the amount of noise my computer is making. My sig shows what I'm running. The case fans are set to low flow and are actually very quiet. The CPU cooler isn't obnoxious but it does turn up the volume when it spins up to high gear. Can't really differentiate between that and the two fans on the GPU but I'm going to buy another 7950 in the very near future and I don't want to hear four fans running.
Out of the box, the Cosmos II has internal positions for three radiators. One mounts in the top, the second can be mounted in the bottom where the side mount fans and lower HDD cages are mounted, and the third mounts on the upper rear just behind the CPU. I found a build thread on another forum where that lower area was modded to fit two radiators and fans for a total of four internal radiators. Given that I'm doing this for noise reduction I'd like to maximize my radiator area/volume. I'm also not averse to using an external radiator so long as I can mount it so that it's not an eyesore.
So, I'd like some recommendations for radiators. The Cosmos II manual calls out 240X2 for the top and bottom and 120X1 for the upper rear. I'm wondering if I could use the 120 for the CPU and run each GPU with its own 240mm radiator. Does that even make sense? The cards are XFX HD7950-TDJC. I'd like to find full cover blocks for those and obviously I'll need a good CPU block. Finally, I'd like to use compression fittings. Personally, I cringe every time I look at a photo of automotive style clamps inside a case. I know it will be more expensive to use compression fittings but I want a clean look and I like the ease of installation they provide.
Please let me know if I need to provide more info.
Thanks,
Mike
Thanks,
Mike
