My build is...
Motherboard - Asus m5a97
HD - 500 GB Seagate Barracuda 7200 RPM's (from HP 2005)
Ram - Corsair Vengence 8 GB 2x 4 GB sticks
Video Card - 2 GB GTX 550 TI
CPU - AMD Black Edition FX-4100 3.6 GHZ
Power Supply - Corsair 620 Watt PSU
Cooling - Cooler Master Hyper 212 + w/ a really high RPM Corsair Fan for Push/Pull
200 MM Intake Fan on side. Front/Back Intake/Exhaust and 2 Top Exhaust Fans
Case - MSI Nighthawk ATX Mid Tower
The bold is what I have questions about. I installed my new heatsink/fan last week a Hyper 212 + w/ an extra fan so it would be push pull.
I have an exhaust fan that the Hyper 212 + is blowing towards and 2 exhaust fans at the top of my case. They are REALLY close to the Hyper212. Both fans basically are above the hyper212 + and my ram.
My question is would the 2 fans at the top sucking air out interfere with the fans that are cooling the processor down? I remember reading some where if you have too many fans close to each other that blow away it wouldnt be good. Since I have basically the 2 fans on the hyper 212+ and the back exhaust fan all facing 1 way would the 2 top exhaust fans be interefering with the cooling going on there?
Here is the best way I can describe it They area all 120 mm fans btw. Couldnt make a spacer so I put ` as the empty space.
```````````^^^^^^^2xFans^^^^^^^
<Exhaust Fan <Fan|Heatsink|<Fan | | (2 sticks of ram)
