- Oct 16, 2014
- Allagash, Maine
I can't comment about the stiffness of the tubing as I am running hard acrylic tube in this build, though I wouldn't recomend it. As far as the ek block follow their install instructions and it's an easy swap. Not sure how much value you will get out of monitoring your temps as once the loop hit equilibrium the temp should be the same all the way through your loop. Those temp sensors will probably restrict your flow more then the EK block, my thoughts only and have nothing to back that up mind you.
these temp sensors had 0 pertruding the inside of the g1/4" female fitting/threads.... seemed as if the fitting itself was to transfer temps through the cable..... as always jumping head first may not be cheapest but fastest way to learn...
the ek waterblock has been installed here for about 4 months.....
I believe the recommendation or info with the water block was "can be used with low or medium flow pumps"
