- Apr 22, 2003
Hey guys,
firing up the desktop for my season fold-fest and im having a bunch of issues with my GTX 1080, it keeps returning failed WUs, then wont download new WUs, then as soon as the CPU is done it wont DL a new WU either. I have no idea where to even start looking, logs done seem to tell me much other then the WU fails. Im on the latest GPU driver(375.70), GPU is at stock speeds and the CPU(2600k) is OC'd to 4.0 with temps around 50-55 at max load and rock solid stability. And suggestions?
Code:
16:45:03:WU01:FS00:0x21:*********************** Log Started 2016-11-12T16:45:03Z ***********************
16:45:03:WU01:FS00:0x21:Project: 9197 (Run 2, Clone 38, Gen 79)
16:45:03:WU01:FS00:0x21:Unit: 0x00000070ab40415c57cb3fdc1779a78c
16:45:03:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
16:45:03:WU01:FS00:0x21:Machine: 0
16:45:03:WU01:FS00:0x21:Reading tar file core.xml
16:45:03:WU01:FS00:0x21:Reading tar file system.xml
16:45:03:WU01:FS00:0x21:Reading tar file integrator.xml
16:45:03:WU01:FS00:0x21:Reading tar file state.xml
16:45:04:WU01:FS00:0x21:Digital signatures verified
16:45:04:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
16:45:04:WU01:FS00:0x21:Version 0.0.17
16:45:10:WU01:FS00:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
16:45:10:WU01:FS00:0x21:Saving result file logfile_01.txt
16:45:10:WU01:FS00:0x21:Saving result file log.txt
16:45:10:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:45:10:WU00:FS01:0xa4:Completed 45000 out of 250000 steps (18%)
16:45:12:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:45:12:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9197 run:2 clone:38 gen:79 core:0x21 unit:0x00000070ab40415c57cb3fdc1779a78c
16:45:12:WU01:FS00:Uploading 2.39KiB to 171.64.65.92
16:45:12:WU01:FS00:Connecting to 171.64.65.92:8080
16:45:13:WU02:FS00:Connecting to 171.67.108.45:80
16:45:13:WU01:FS00:Upload complete
16:45:13:WU01:FS00:Server responded WORK_ACK (400)
16:45:13:WU01:FS00:Cleaning up
16:45:13:WU02:FS00:Assigned to work server 140.163.4.242
16:45:13:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 140.163.4.242
16:45:13:WU02:FS00:Connecting to 140.163.4.242:8080
16:45:14:WU02:FS00:Downloading 4.23MiB
16:45:15:WU02:FS00:Download complete
16:45:15:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11403 run:4 clone:25 gen:284 core:0x21 unit:0x000001768ca304f255ed4f533f19d80b
16:45:15:WU02:FS00:Starting
16:45:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/m_s_j/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 11732 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:45:15:WU02:FS00:Started FahCore on PID 6564
16:45:15:WU02:FS00:Core PID:9876
16:45:15:WU02:FS00:FahCore 0x21 started
16:45:17:WU02:FS00:0x21:*********************** Log Started 2016-11-12T16:45:16Z ***********************
16:45:17:WU02:FS00:0x21:Project: 11403 (Run 4, Clone 25, Gen 284)
16:45:17:WU02:FS00:0x21:Unit: 0x000001768ca304f255ed4f533f19d80b
16:45:17:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
16:45:17:WU02:FS00:0x21:Machine: 0
16:45:17:WU02:FS00:0x21:Reading tar file core.xml
16:45:17:WU02:FS00:0x21:Reading tar file system.xml
16:45:17:WU02:FS00:0x21:Reading tar file integrator.xml
16:45:17:WU02:FS00:0x21:Reading tar file state.xml
16:45:18:WU02:FS00:0x21:Digital signatures verified
16:45:18:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
16:45:18:WU02:FS00:0x21:Version 0.0.17
16:45:26:WU02:FS00:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
16:45:26:WU02:FS00:0x21:Saving result file logfile_01.txt
16:45:26:WU02:FS00:0x21:Saving result file log.txt
16:45:26:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:45:28:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:45:28:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11403 run:4 clone:25 gen:284 core:0x21 unit:0x000001768ca304f255ed4f533f19d80b
16:45:28:WU02:FS00:Uploading 2.42KiB to 140.163.4.242
16:45:28:WU02:FS00:Connecting to 140.163.4.242:8080
16:45:28:WU02:FS00:Upload complete
16:45:29:WU02:FS00:Server responded WORK_ACK (400)
16:45:29:WU02:FS00:Cleaning up
16:45:29:WU01:FS00:Connecting to 171.67.108.45:80
16:45:29:WU01:FS00:Assigned to work server 140.163.4.243
16:45:29:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 140.163.4.243
16:45:29:WU01:FS00:Connecting to 140.163.4.243:8080
16:45:29:WU01:FS00:Downloading 2.67MiB
16:45:30:WU01:FS00:Download complete
16:45:30:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11707 run:46 clone:20 gen:54 core:0x21 unit:0x0000004b8ca304f357e9eae924e0cf27
16:45:30:WU01:FS00:Starting
16:45:30:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/m_s_j/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 11732 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:45:30:WU01:FS00:Started FahCore on PID 5280
16:45:30:WU01:FS00:Core PID:10820
16:45:30:WU01:FS00:FahCore 0x21 started
16:45:32:WU01:FS00:0x21:*********************** Log Started 2016-11-12T16:45:31Z ***********************
16:45:32:WU01:FS00:0x21:Project: 11707 (Run 46, Clone 20, Gen 54)
16:45:32:WU01:FS00:0x21:Unit: 0x0000004b8ca304f357e9eae924e0cf27
16:45:32:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
16:45:32:WU01:FS00:0x21:Machine: 0
16:45:32:WU01:FS00:0x21:Reading tar file core.xml
16:45:32:WU01:FS00:0x21:Reading tar file system.xml
16:45:32:WU01:FS00:0x21:Reading tar file integrator.xml
16:45:32:WU01:FS00:0x21:Reading tar file state.xml
16:45:32:WU01:FS00:0x21:Digital signatures verified
16:45:32:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
16:45:32:WU01:FS00:0x21:Version 0.0.17
16:45:37:WU01:FS00:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
16:45:37:WU01:FS00:0x21:Saving result file logfile_01.txt
16:45:37:WU01:FS00:0x21:Saving result file log.txt
16:45:37:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:45:40:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:45:40:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11707 run:46 clone:20 gen:54 core:0x21 unit:0x0000004b8ca304f357e9eae924e0cf27
16:45:40:WU01:FS00:Uploading 2.41KiB to 140.163.4.243
16:45:40:WU01:FS00:Connecting to 140.163.4.243:8080
16:45:40:WU01:FS00:Upload complete
16:45:40:WU01:FS00:Server responded WORK_ACK (400)
16:45:40:WU01:FS00:Cleaning up
16:45:40:WU01:FS00:Connecting to 171.67.108.45:80
16:45:41:WU01:FS00:Assigned to work server 140.163.4.243
16:45:41:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 140.163.4.243
16:45:41:WU01:FS00:Connecting to 140.163.4.243:8080
16:45:41:WU01:FS00:Downloading 2.67MiB
16:45:42:WU01:FS00:Download complete
16:45:42:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11709 run:1 clone:177 gen:32 core:0x21 unit:0x000000428ca304f357ed33dbc677fc96
16:45:42:WU01:FS00:Starting
16:45:42:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/m_s_j/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 11732 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:45:42:WU01:FS00:Started FahCore on PID 12156
16:45:42:WU01:FS00:Core PID:12196
16:45:42:WU01:FS00:FahCore 0x21 started
16:45:44:WU01:FS00:0x21:*********************** Log Started 2016-11-12T16:45:43Z ***********************
16:45:44:WU01:FS00:0x21:Project: 11709 (Run 1, Clone 177, Gen 32)
16:45:44:WU01:FS00:0x21:Unit: 0x000000428ca304f357ed33dbc677fc96
16:45:44:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
16:45:44:WU01:FS00:0x21:Machine: 0
16:45:44:WU01:FS00:0x21:Reading tar file core.xml
16:45:44:WU01:FS00:0x21:Reading tar file system.xml
16:45:44:WU01:FS00:0x21:Reading tar file integrator.xml
16:45:44:WU01:FS00:0x21:Reading tar file state.xml
16:45:44:WU01:FS00:0x21:Digital signatures verified
16:45:44:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
16:45:44:WU01:FS00:0x21:Version 0.0.17
16:45:49:WU01:FS00:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
16:45:49:WU01:FS00:0x21:Saving result file logfile_01.txt
16:45:49:WU01:FS00:0x21:Saving result file log.txt
16:45:49:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:45:53:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:45:53:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11709 run:1 clone:177 gen:32 core:0x21
