Was browsing ebay for a case and stumbled upon this auction:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120625656675
Thought it looked like a great deal as the case alone goes for more than $300. I talked to the seller before I bid and asked if he'd cut me a deal on the water block and the fans. He said if I won he'd give me the fans and block for free!
So I'm getting a brand new Silverstone TJ07
with:
D-Tek Fuzion-V2
ThermoChill PA120.3 radiator
Swiftech MCP-655 pump with Gel Pad from Petra's
EK-Multioption 150 Reservoir with water temp probe installed
3- Scythe SFF21F-120mm fans all wired and sleeved
Danger Den Brass style Top fillport
10' Tygon R-3603- 1/2" Tubing and clamps
also comes with performance pc side panel and casters
Slowly putting together the rest, already have a gigabyte x58 ud3r. Will be picking up a i7 930 or 950 from microcenter in a week or two(not sure which one). Plan on running kingston hyperx 1600mhz memory, most likely 3 x 2gb. Temporarily going to be running one ecs 8800gt with accellero cooler. One thing, biggest power supply I have right now is a corsair 750tx, not sure if this will run everything. Will be purchasing a corsair 950tx next.
I'm not interested in cooling graphics cards anytime soon, so I'm just wondering if this setup here is going to be good enough or if I should upgrade the block, etc?
with:
D-Tek Fuzion-V2
