- Jan 19, 2004
- Tennessee
I was considering upgrading, but after advice and seeing benches, I think I'm just going to get an NH-15 and OC my CPU to current speeds. I'll be using an ASRock Extreme4 if that's the path I take, as I need to replace the mobo.
Currently, the machine in question has two 4GB 760's in SLI. Games which fail to take advantage of SLI properly, such as Fallout 4, are beginning to suffer. I game at 1080p and will go from that straight to VR on an HTC Vive. A single card solution seems like the wiser move right now.
This leaves me with questions.
* Will the 2600k overclocked be enough to push VR, since technically the minimum processor for the Vive is a later-gen i5 that is a little slower?
*Am I better to go with the 1080 or the 1070, since both are very much capable of supporting VR, since I game at less than 4k when doing conventional gaming?
*If I were to buy today, I couldn't get my usual brand (EVGA) due to limited availability...so would Xotac, MSI, or any other brand give me the same reliability EVGA has? Who should I avoid?
It's been years since any of this has been a concern, so I'm a bit behind the times. Thank you in advance for your advice!
