I'm gonna start off by saying this: I've been out of the loop ever since my 3770k 780 build. Since then I've only built one pc for a friend which at the time was an easy choice, 6600K, 1070 GTX.
But with all the recent announcements and release of zen I've got more of a plate for my personal build which will be mostly gaming and some content creation / streaming. I guess I also do a fair bit of compressing and document work.
So I was leaning towards the Ryzen 1600. If there is a better processor for my needs I'm all ears.
SOOOO. Which mobo should I pair with the beast? I can't find anything about the VRMs on these boards, but if Asrock is still as much of a beast as they used to be (12+4 power phases etc compared to 8+2s of asus at the time) I suspect Asrock is the way I should go.
op1
https://www.newegg.ca/Product/Produ...7760&cm_re=asrock_x370-_-13-157-760-_-Product
op2
https://www.newegg.ca/Product/Produ...7769&cm_re=asrock_x370-_-13-157-769-_-Product
op3
https://www.newegg.ca/Product/Produ...7758&cm_re=asrock_x370-_-13-157-758-_-Product
If there is another board I should consider please post. The ASUS x370 pro looked really cheap in comparison to these asrocks. I also noticed that most chips paired with gigabytes aorus mobos are only hitting 3.8/3.9 and rarely 4GHZ which is where I want my chip to sit on, paired with a NHD15 most likely.
op1
op2
op3
