I was lucky enough to be able to pick up a couple of the 40GB kingston SSDs. I'm presently running them in a RAID 0 configuration on an older NVIDIA 680i motherboard. I've installed Windows 7 and a few games. I've also got a 150GB Raptor and a 500GB WD Caviar in the system for apps and files. My main storage is a 4.5 TB Windows Home Server. Very impressed with the benchmarked and subjective speeds that I'm seeing. In particular, I've never seen Flight Simulator X run as smoothly as in this config.
My main use of the system is web surfing and gaming.
My main question is how to properly maintain these drives over time? It's unlikely that I'll have access to Windows 7 TRIM anytime soon because of some combintation of the Kingston drive, the limited BIOS options of my mobo, and the RAID configuration.
How much of a problem is this likely to be with these Intel G2 drives? Is there anything I can or should do in the meantime to keep them running as well as they are now?
I've been researching the issue all morning and can't seem to find any definitive advice.
Thanks.
Thanks.
