- Aug 6, 2015
- Romeoville, IL
- Thread Starter
- #21
I used screws to attach two of the Phobya fan hubs and it works really well. The Lamptron CW611 doesn't use PWM so I had to create some custom cables that would go from the fan controller to the fan hub. Routing the fans to the hub was really simple and clean. I decided not to go with the push/pull at this time so 1 fan hub went to power the fans on the top 2 480 rads and the other will power up the fans on the 480 rad in the basement.
