- Sep 7, 2003
- Warsaw, Poland
I rather meant styrodur and balsa as they're harder and more resistant. Styrofoam might do its job, but I'da rather go with one of those 2.
insulglass said:Looks very nice my friend. Kudos for sticking with it... most people do not invest in the time required to produce such a beautiful finish.
Can I assume that BOTH your heat sink and CPU have similar finishes?
Dave
[email protected]
www.easypckits.com
Sneaky said:my waterblock is already machine lapped to 2000grit or some, and it was connected to the hoses and junk - i was itching to lap it as well, but didn't feel motivated to drain the system to lap the block at the moment
btw - you'll have an order for a couple of your kits soon (i did this lapping with a smaller frozencpu.com kit that i got a couple moths ago)
Susquehannock said:Sorry, but that plastic backed stuff is marginal at best IMO. Dave gave me
one of those kits to try out. And he wasn't happy with my opinions apparently
because he just ignored me afterwards.
The abrasive on that plastic stuff isn't attached to the backing very well
from what I've seen. Best to use the good old standard - 3M paper.
It's been working fine in the machining industry for decades.
You can get a very shiny surface with 2,000 grit provided you take your time
to clean everything often, and know what you are doing.
Tried to get a finish like above with the plastic stuff, it kept snowballing as
the abrasive particles came away from the backing.
And I agree that anything smoother than an 800 grit finish is a waste of time.
Took the above finish back to fresh 800 grit. Got the same temps. Lapped
it back to a mirror again, same temps. Even tried remounting the sink, same temps.
The important thing is to have a FLAT and consistant surface.
Many times when you get a new heatsink the bottom is slightly dished from
the milling process. And can even have deep cutter marks too.
As always ... JMhO.
9mmCensor said:How was that picutre taken?
SolidxSnake said:no, but... the actual processor was in mirrored writing, and the heatsink was normal.... erm...
Ol'Dusty said:I think this kit looks great and looks like a very good value. My question is, that in all this talk I havent seen where anyone has ruined a CPU. Is that something that happens? I must say as someone who's new to all this, sanding the CPU sounds a bit scary. But then again the wife thought I was nuts when she saw me taking the drill and dremel to the new case I'd purchased.
Susquehannock said:Hey Dave ... please don't get the idea I have any negative feelings. It was great of
you to provide a kit for me to try free of charge. No doubt about it.
It's just that I got the impression you weren't too happy with my opinions that's all.
Then again, looking back it's very possible you got busy and didn't have time to
respond is all.
The two problems I had were - snowballing and the pieces were too small (quarter sheets)
For the record, I am still certain your kits are the best option for most people here who
don't have the time or resources to go and buy the respective grits needed to get an
optimum lapp job. Particularly since you include the glass as well.
The kits are just not the best option for me, that's all.
Why did I have problems? .. not sure.
All I can say is I used more than enough water. I am avid about cleaning everything off
between every few passes across the abrasive to remove any random particles. And about
not applying much pressure at all in the final stages ... just the weight of the
sink itself is all the pressure that's applied. No way to get a perfect mirror otherwise IMO.
Like I said, I have tried other plastic backed sheets since with similar results.
They do work well, for a short time. Just don't seem to me to be as durable
as the classic 3M stuff I've been using for years & years. But that's just me.
Again, sorry if I came across the wrong way above ... wish you the best of luck as well.
*Partial Quote, please refer to insulglass's entire post for complete explanation* -consumer9000insulglass said:I wholeheartedly disagree, and here's why.
CPU dies are manufactured to millionths of an inch tolerances, even the outer surfaces. I'll grant that the HEAT SHIELD may convex or concave, but CPU surfaces are generally as flat as you can lap a heat sink. That's why you can potentially lap CPU's with a heat shield for even better thermal performance (but that's a topic for Liquid3D and Silversinksam!).
