sure, it's possible, the die of the CPU is not protected by a heat spreader as it is in a desktop part. Did you replace the thermal interface material between the cooler and the CPU?
Also I'm not sure if this will fix what is causing your white screen issue, it could be so many number of things, but without replacing the thermal interface you''ll wind up with out of control thermals. I do suppose it could be bad enough to make the laptop not boot, but I would expect a black screen rather than a white one.
Haven't yet been able to figure this out. Could the mods move this to more appropriate section, this maybe the wrong one?
