- May 2, 2002
- Keller, TX
i've been drooling over the picture frame PC at mini-itx.com for a while now and i'm wanting to know if a laptop LCD can be connected to a DVI or VGA output without too much work?
Yep.Is_907 said:oh... there are non-C3 itx mobos?
Is_907 said:interesting... where does one purchase a ITX board?
Captain Slug said:
Newegg, Directron, Idot.com, and caseoutlet.com are the only ones I know of.
THere aren't very many models available and most of them are part of a barebones system.
Is_907 said:UnseenMenace: thanks for the info...
well, this system will be for DVDs, DivX, web browsing, chatting and a bit of HTML and PHP coding... that's all i usually do on my main desktops anyway (well, there is the occasional Worms game =)
so unless you think there's not enough power for that... (i'll be using the M9000 or M10000 board)
UnseenMenace said:I am afraid that you are WRONG All Mini ITX motherboards are powered by Via processors either the Eden or the C3. The form factor requires the processor to be hard soldered to the mobo.. The Mini ITX form factor is 170 mm x 170mm square and is the smallest desktop form factor available.
The small form factor which features the P4 and AMD processor solutions is called Flex-ATX and is larger and higher than Mini-ITX..
Captain Slug said:
Shuttle makes ITX P4 and socket 370 systems but don't recommend those since you can only get them in conjunction with the case, PSU, and heatsink unit. ECS and Biostar are also developing Socket 370 ITX and Mini-ITX motherboards. They accomples fitting the parts in such a tiny space by moving some of the integrated chips onto the back of the PCB.
Flex ATX alots space for 3, sometimes 4 expansions slots. It's max dimensions are 9.4" x 7.5"
ITX alots for two PCI slots and measures 7.5" x 7.5"
Mini-ITX alots for only one expansion slot and measures 6.9" x 6.9"
The variety of ITX and Mini-ITX boards is greater outside of the United States because the U.S. market is primarily that of the gaming arena. And area in which the small integrated boards don't perform as well in. A number of Mini-ITX products have to be special ordered or imported directly from the manufacturer.
1.1. What is the mini-ITX form factor?
Whilst sharing much with it's older siblings Micro-ATX & Flex-ATX, mini-ITX is actually quite different in some very important ways
The maximum mainboard size is only 170mm x 170mm, where Flex/Micro-ATX can be much bigger.
A Mini-ITX PSU is less than 100 Watts.
Is_907 said:http://www.mini-itx.com/reviews/b860t/
a Jetway SFF (Small Form Factor) which seems to fit Slug's description of ITX (larger than mini-itx)
The Mini-ITX whitepaper itself lists ITX (not mini) on page 7 as being 215mm x 191mm.UnseenMenace said:Shuttle do not make Mini ITX based systems they make small form factor systems look here . The small form factor is Flex ATX.. Email them to check. Small form factor is simply not the same as Mini form factor.
its also worth looking at the specification required for a product to be considered Mini-ITX
UnseenMenace said:I am very interested that ECS and Biostar are apparently considering the form factor and was wondering if you could provide a link to this information or a source
The biggest developments are coming from the newer standard TFX12V power supplies with are both small, quiet, and currently can pack a 200w wallup. Most manufacturers are however optiong for 1u rackmount power supplies which max out at 300w. So as you can imagine, IF a company were to invest in it they could produce a full power machine in ITX form factor. But there's curently a very limited market in which these would sell so the R&D investment may not be worth it since these machines aren't that popular in the largest market for PCs (i.e. the US, which doesn't worry about space).UnseenMenace said:Now unless im mistaken, have you ever tried running a pentium 4 on 100 Watts, Intel did and that is why they specify a higher power requirement and produce the mobile processors for systems that did not have vast amounts of power available to them such as laptops.
