- Jan 13, 2014
So I got my pump yesterday and hook everything and performed a leak test overnight.
1/3 of my bitspower 150ml was empty, that's toomuch to be air bubbles.
Since I had to come to work I did not had time to Look at it so I replaced the towels with individual ones (had a microfiber one only earlier). Attempt to tight the suspect fitting giving issues and head to work.
I have no idea how to troubleshoot this properly.
As in what to check and how to.
1 thing I did notice is that my monsoon key(wrench). Had a really hard time getting to the fitting (tubing seemed wider than normal).
Stuff I don't know how to verify,
- is new pumps more pressure than last( mcp 35x (new) vs mcp 355)
- tubing is old/bad
- fitting not tight enough (without taking everything appart)
- radiator got bad after assembling?
- 90 degree connection got bad/ to loose
- is the tubbing to kinked and need a angle fiiting?
Ps: when testing components out of case I did not notice leaks. Issue caused after plugging everything in.
NOTE: SUSPECTED LEAK IS, from cpu to 120 mm on rad side, Or from 120 to 360. , 360 side
1st leak in 10+ months
- tubing is old/bad
