- Jul 5, 2003
- Frederick, MD
Never have WC'd my PSU...MLMIB said:so you don't wc the psu anymore? also, anyone know why my temps are so high?
I would like to over fall break cut out most of the metal in the front to let better air in, but I can't do that now
I disconnected the fans in the back to see how that would help with the noise and there was no audiable difference
when I cut most of the tubing I needed it that long to make the bends w/o kinking
What is the coolant mixture made of? Looks like there is alot of addative in there.
Any padding under the Eheim? They are silent if the vibrations are isolated from the case.
Yeah, cut the metal out of the front and GET A RHEOBUS... That will be a BIG improvement.MLMIB said:well I disconnected the fans in the back to see how that would help with the noise and there was no audiable difference, so I just leave them in to help(the black one that looks weird is over the mosfets to help keep them cool, I used to get weird restarts over the mosfets overheating)
where else can I put the rad? I could get 2 of those small 80 mm rads and put them where those 2 fans in the back are(it's not a full server size, so I dont' have a spot over the psu) but I don't see any other spot to stick the rad(I would like to over fall break cut out most of the metal in the front to let better air in, but I can't do that now(maybe I can, talkin to a friend about it, will that help?) when I cut most of the tubing I needed it that long to make the bends w/o kinking. any idea's to the above?
Yes they do have 3 1/2" bay controllers, but I recommend you stick with the 5 1/4" controllers... Just run the pump cord through the 3 1/2" bay, or better yet, splice the cord into the PSU.MLMIB said:okay, can't stand the pump on end like that, it's already pinched and wedged under my tv tuner, I'd like to get a fan controller, but do they make them for floppy drive bay area's? 'cause thats the only spot I got free, I run my pump's plug out through an empy 5 1/2 (I guess I could switch it so the cord runs through the floppy bay area.... if need be, I just pulled a hd out(again, to cut noise)) hmmm, well I run full load 24/7(fold), but I'll cut the front out and see if that helps, any advice for a fan controller?
My 9800pro's stock fan like tripled how loud my system was! Right now I'm on a passivly cooled GF2 MX and the pump makes more noise than the rest of the system, followed my the hard drive, followed by nothing since there are no other moving parts...BeerHunter said:There is no way aircooling can be as quiet as water. I've tried and spent hundreds of dollars on so called "quiet" cases/fans/psus etc.. Just a 60mm fan off a 9800pro makes more noise than my whole system combined.
How? I only have 2 120's at 5volts in my whole system and still overclock moderate.
Decide whats making the noise and eliminate it. Do so by 5 or 7 volting fans or eliminating them all together.
My rec is 5 volts the two rear 80's, get a seasonic 120mm fanned 460W PSU and 7 volts some new of these http://www.newegg.com/app/ViewProductDesc.asp?description=35-150-032&depa=0
The quietest fans you can buy at that volts.
Here's an old pic of my rig but you can see how quiet it would be only having two fan.Cyrix_2k said:My 9800pro's stock fan like tripled how loud my system was! Right now I'm on a passivly cooled GF2 MX and the pump makes more noise than the rest of the system, followed my the hard drive, followed by nothing since there are no other moving parts...
I wouldn't unplug the fan... It really does drop temps (atleast it did with me...) alot when running low fan speeds.Etacovda said:Well, you can unplug the 'pushing' 120mm fan, because push/pull does almost nothing to your temps. Definitely mod the front of the case, and fan control the 120mm's. That'll drop your volume nicely.
