- Jul 5, 2003
- Frederick, MD
Nice... The only problem I might see with your setup noise wise would be the HDD... Even the quiet ones make too much noise for me. I personally have a 40gb Maxtor with the Fluid bearing stuff and I can STILL hear the stupid thing. I really need to build a foam box around my hard drive and pump to get rid of the noise.BeerHunter said:Here's an old pic of my rig but you can see how quiet it would be only having two fan.
As for pump, I found 99.9999% of peoples pump noise is from vibration. either impellor or case vibration. There are impellor mods you can do, even to the ehiems, probably the most quiet pump in the world.. Case vibration is solved either by elastic suspension of pump or setting it on foam.
Where is your HDD in that pic? I don't see it... Also, is the NB passivlly cooled?
::edit:: My NB fan's making all the noise... NOT the HDD!!! Time to mod
