I would highly recommend just getting a new case. The Xaser is really hard to get the noise down as the fan grills are very restrictive and there are way too many fans. My suggestion is to get a case with 2x 120mm fans/fan mounts. and then mount some panaflos and clean up the wiring. Then you could get a Zalman or something.
If you don't have enough money though, you could cut out the fan grills, get lower dba fans and tidy up wiring. I would also put a drop of oil on some of the bearings on the fans(just a drop). if you want, you could get a duct and then mount a fan on the sidepanel and get a zalman cnps7000-alcu or something.
-1cem4n
-1cem4n
